0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The crush sleeve is the one that fits between the bearings. There probably won't be a spacer between the pinion flange and the front pinion bearing cone. The crush sleeve is a one-time use item, so it might be necessary to procure a new one if you're reassembling a rear end with used parts. I hope you checked the tooth contact pattern before disassembly, as it's possible to build in a gear noise unless you get lucky and assemble the gears in exactly the same relationship as they came apart. Jerry
