| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | DOT 3 is recommended for older brake systems. DOT 4 is for more modern systems and might cause the rubber parts to break down. DOT 5 is a silicone based fluid and I have no experience with it. If DOT 3 is available I would use it. Are there any other thoughts out there?
Steve H
