I know in Europe after WWII they used to convert cars to run on kerosene (or what they referred to a paraffin. They would add a plate between the head and the block to lower compression and built a heat shield around the exhaust manifold and intake to warm the intake from the exhaust.
You would probably have about 1/2 the power running on kerosene.
