3 members (Nick in Manitou, Sjm, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | 3/16" steel lines have a 3/8" flare nut, and the rubber flex lines will have 5/8" wrench sizes on both ends. The line coming from the master cylinder to the front and rear T-blocks will probably be 1/4" diameter tubing with a 7/16" nut. The upper end of a rubber flex line will also be locked into a bracket on the frame that restricts it from turning, but I always use a flare nut wrench as a backup anyway.
