0 members (),
119
2
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 27 Junior Member | | Junior Member Joined: Mar 2007 Posts: 27 | well guys i'm happy to report that after working on this thing last night till 2am this morning it fired up and ran first try!!!! last night i put in a new fuel pump, fresh gas, rebuilt the entire carb, drained the antifreeze, new 160 thermostat (had none) and a new radiator cap.
sounds good! even with no muffler. one thing i noticed is noisy rockers. i got a new valve cover gasket and plan on taking off the valve cover this weekend and hopefully tighten/adjust the rockers. any tips???
other than that sounded great. to my surprise the gauges all work. water temp was in the middle. oil preasure was 30lbs at idle (with fresh 10-40 oil) and went up to 50-60 when i hit the gas. amps looked good although i dont know how that works since the truck is 12 volt?! i let the truck run for a good 15-20 min this morning
i've yet to try to do the compression test again. but hopefully this weekend.
so far:
new plugs new points and condensor new plug wires new cap and rotor new 12volt coil new fuel pump fresh oil 10-40 new 160 thermostat new radiator cap fresh antifreeze new air filter new fuel filter new rubber fuel lines rebuilt carb new battery cables/ engine wiring new radiator hoses drained gas tank, fresh gas new battery
so after all i've done anything else you guys recommend for me to change as far as the engine? other then a new belt which i have to go get. i think im also gonna replace the one wire alternator, it's working but looks really corroted, rather change it now then have it leave me stranded. next i plan on doing brakes and suspention.
thanks again for all you guys help!!!! | | | |
Entire Thread
car wont fire, no spark
| CooleThanEthan | 03/29/2007 8:10 PM |
Re: car wont fire, no spark
| project 39 | 03/29/2007 9:11 PM |
| project 39 | 03/29/2007 9:13 PM |
| Wrenchbender Ret. | 03/29/2007 10:56 PM |
| beltfed | 03/30/2007 12:33 AM |
| fredoly | 03/30/2007 3:38 AM |
| CooleThanEthan | 03/30/2007 5:06 PM |
| atomarc | 03/30/2007 5:49 PM |
| waldo53 | 03/30/2007 5:54 PM |
| beltfed | 03/30/2007 9:17 PM |
| CooleThanEthan | 04/03/2007 4:50 PM |
| CooleThanEthan | 04/03/2007 4:52 PM |
| Baldy | 04/03/2007 5:43 PM |
| atomarc | 04/03/2007 5:52 PM |
| Flxible | 04/03/2007 6:01 PM |
| CooleThanEthan | 04/03/2007 6:26 PM |
| LAROKE | 04/03/2007 6:53 PM |
| CooleThanEthan | 04/12/2007 5:03 PM |
| Brendan M | 04/12/2007 7:44 PM |
| Beaver 53 | 04/13/2007 2:52 AM | |
