8 members (treegrower, Otto Skorzeny, Bill Hanlon, oldieoldie, Rusted Nut, 66flea, TUTS 59, jmoore), 89 guests, and 1 robot.
Topics128,268
Posts1,058,187
Members48,482
Previous Gallery
Next Gallery
#1415153 06/28/2021 2:56 AM
6 Images
1958 Chevrolet 3600 NAPCO
Family owned since new, 235, 4 speed, line built NAPCO, Cardinal Red/Bombay Ivory trim. Mods - power master cylinder, 285/75/16 radial tires, alternator, high tone horn, fuel cell located behind rear axle.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
7 Comments
It's hard to give me truck envy: but this does it.
I bet it's a workout to steer those tires!
'59 Chevy Suburban, NAPCO
Looking at your story in the gallery, it looks like you did a lot of good stuff on this truck. It is a real beauty.
Do you know where to find tech specs for the Napco conversions? I have been curious about it for a long time, but can't find a decent resource for hard info. Things like the new spring rates/sizes, how much the body is lifted compared to the 2WD, that kind of thing.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Here's some specs:
http://chevy.oldcarmanualproject.com/chevyresto/58t099.htm
Mine has 6" lift blocks on the rear axle.
That is a Beautiful truck ! Thanks for sharing with us !
Jim
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
I will be converting the headlights to a relay controlled setup this summer. I ran dedicated ground wires from the bulbs and still have kick-out from the headlight switch overload. I bought a kit from Daniel Stern Lighting that has HID elements inside GE bulb Pods sourced from Belgium; they look like OEM if you don't put your head next to them.... I am excited to drive it this summer and not have the lights kick off. Now all we have to do is have our administration fix the gas crisis.
I replaced the BFG radials with Cooper Discover radials (made in Ohio!!!) and went up one size to gain some more diameter. 285-75-16...
It doesn't steer to bad with the tires set to 50 psi!
The truck is a line built NAPCO from Willow Run Michigan, Chevrolet started this in mid production year for the 1958 truck.
Not a show goes by that someone asks me what kind of a lift I have on it.......
"Calvin"
If I remember Lugo did this truck? Is it a factory original resto? I'd like to see some in cab pictures and the bed wood. I think it was a Lugo restoration I saw that was the best ever resto I saw that was close to factory stock.
Way nice. Thanks for sharing 👍
