2 members (Sjm, baldeagle), 178 guests, and 3 robots.
Topics128,254
Posts1,057,979
Members48,478
#694100 11/12/2010 12:31 AM
Both hoses that run from the blower unit to the defrost deflectors on my '52 Big Bolt were missing when I bought the truck.
I made new ones by using 1 1/2" sump pump discharge tubing (similar to Shop Vac hose) and 1 1/2" x 1 1/4" rubber fittings (PlumbQuick brand).
The hose is sturdy and flexible. The rubber fittings slip snugly (with a little spit for lubricant) onto the blower/deflector opening. The built-in hose clamps are nice. I did it all for under $20.00!
http://picasaweb.google.com/hillbilly6977/StoveboltHeaterHoses#
1952 Chevrolet 6400 2-Ton Flatbed Dump Truck
Video on YouTube
Nice.
Robert French MY3800FIRETRUCK
That is Nice.
Professional Novice
Thanks for sharing Bruce. I know I'll be looking for hoses soon.
~Jim
Does the flexible hose stay firmly attached in the rubber connector using the hose clamps? Seems like the flexible hose wouldn't be sturdy enough and would just keep collapsing?
I need some hoses, so you help is appreciated!
Suprisingly, yes, it holds together well.
The rubber boot is firm enough that it cannot be tightened so much that it crushes the tubing. But, it can be tightend enough that the two pieces stay connected without coming apart.
Believe me when I say it took some "finagling" to install the hoses up under the dash. The hardest part was trying to lay on the floor next to the shifter, parking brake and dump box lever.
I made the passenger-side hose twice as long as was needed so I had some slack to work with. Having the radio missing was nice because I could see what I was doing!
Video on YouTube
Very inovative, and I don't mean to take the wind out of your sail, however I have to point out that a pair of the correct Defroster Duct Hoses are avalable from all of the vendors for less than $15.
DG
Denny G
Sandwich, IL
$15 + the shipping would probablly be around the same. I like 'em. thumbs_up
Robert C.
I'm a Genius in the making.
1950 3600
I had a little time and wanted to get the defrost working right away. I could have bought some, but I had fun getting creative.
Now, if I could only make a passenger-side mirror!
Video on YouTube
Nice work
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
Loren
You are like me. Sometimes it is fun just to see if we can make something from scratch even if it is available. Thats thinking outside the box.
Bowtiefan: my first hope was to find flexible hose with the same diameter as the heater/deflector so I could just slip them on and be done. Thinking outside the box happened when I couldn't find 1 3/4" hose! Thanks for the reply.
Video on YouTube
