5 members (37 GC, Dusty53, sron48, Vice-Grip, Otto Skorzeny), 130 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
#3 09/01/2004 7:48 AM
Are the GM/Eaton HO-x2 series axles under 3/4-ton and 1-ton AD trucks the same, or do they have different sized brakes and other parts? Are the '67-'72 brake drums the same diameter and depth? The later finned drums would be nice if they are the same in all other respects.
1954 GMC De Luxe COE
#4 09/01/2004 11:45 AM
The housings are the same pattern with different lengths of tubes. Brakes got larger with increases in gross weight. The brake sizes also increased as time went on due to DOT regs and increased speeds.
What you could probably do would be to take the drum assembly off a newer model and bolt it on to an older. You would also have to check the axle length to be sure it would still work. I know that you can interchange parts on the different years of axles.
They seem to have left the bolt patterns the same and used what is called "interchangeable at attach points". One example of this is the pumpkin swap, where the entire carrier assembly can be swapped, but the individual components won't interchange.
Fred
52 3600
69 C-10
#5 09/01/2004 6:18 PM
Will a Chevy 67-72 3/4 ton complete carrier assembly replace a 47 3/4 ton assembly ?
#6 09/01/2004 8:08 PM
Yup. Check the technical section of oldgmctrucks.com for details.
#7 09/01/2004 9:53 PM
Thanks GMCpanel.
I'd be interested to know what you figure out regarding the drums and related brake parts interchange.
