1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 34 | Of all the systems I don't know much about, the electrical system has to be near the top of the list.
My wiring looks messy, some is loose, some has old insulation, some is new and I suspect that some of it is not automotive grade. So, I was looking at the Jim Carter wiring harness. The photo in the catalog looks like a lot of wire, but what does it include? Just what wires does it replace?
How difficult is it to install? Is it just a matter of detaching and attaching replacment wires piece by piece? Do the instructions alone get you through the job, or do you need to add a wiring diagram and real automotive electrical knowledge to get it done right?
Also, I see that there are generator and alternator versions. When did Chevy switch from a generator to an alternator? And the most elementary question, how do I tell whether my truck (a 55 3100, series 1) has a generator or an alternator?
Jeff
Trooper Jeff If I can't drive my truck, fetch my horse "Courage is saddling up even though you are scared to death" - John Wayne
| | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Do the wiring harnesses come with with wiring for gages too?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, appropriate for the year
Bill | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | So this 149.00 wire harness from Classic Parts - seems it goes through the firewall once.
Anyone use this before?
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | So that harness was rather easy to use. It is basic and did not have a cigarette lighter wire - but everything went to gether well. You have to run your own wire to the Tailights.
should be ready to fire it up this weekend | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Cigarette lighter was an accessory, installed by dealer, owner, etc after delivery.
Wiring for brake/tail/signal should be included. You run the wires you need based on one original-style lamp for rear stop/tail or two lamps for rear stop/tail/signal.
Thanks for the report. Let us know how this proceeds.
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I know this post is 6 months old but I was wondering the same things 53cowboy was. Its really hard to tell from the pictures in the Classic catalog (or any catalog), are the bulb holders for the gages included too? What about the running light and taillight bulb holders? I would guess the taillight and running lights themselves have a pigtail on them that plug into the replacement harness.
So 53Cowboy or TrooperJeff how did things turn out?
Joe (55 First series)
1955 First Series 3100
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I've purchased the 52-021 (47-49 w/ generator) harness from Classic Parts. I have not installed it yet, but have been studying it in preparation of the project. Mine does have the instrument panel bulb holders (though some folks have been critical of them since they are plastic.
The harness has wires for the running lights, brake lights, etc, but they are clipped to length. The kit came with additional wire to complete runs, down the frame presumably, and a few spare sets of connectors. There are not bulb holders included for the chassis lights, but it did come with the short harnesses for the headlights and includes wiring for optional turn signals.
Hope this helps. Have fun.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | |
