0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 5 New Guy | | New Guy Joined: Feb 2013 Posts: 5 | Hi everyone. I am looking to put a full pressure 235 into my 1936 chevy 1/2 ton. I found a 1954 bel air original engine but I want to try to keep the stock look as much as possible. Will an earlier head fit on this block? I know a 53 full pressure engine did have a center bolt valve cover. 54 is the first year for the perimeter bolt on style. I'm thinking a 53 head would fit but just a guess. This motor is a 54 powerglide car motor. Thanks!! Ron.. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | All you need to do install the rocker arm studs from the earlier motor on the 54 head. Then you can install the earlier valve cover.
T take it your truck was born with a 207? | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | The Offenhouser valve covers for the later 235's used studs through the rocker arm stands and mounted like the 216s so I would have to assume that it will work. If you use the 235 valve cover though, the gaskets stick out around their side bolt holes. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As truckernix said, you just need to replace the two bolts with studs to use that style cover. The only problem is you can only use a 1937-53 cover. Your 1936 cover is to long for a 235.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2013 Posts: 5 New Guy | | New Guy Joined: Feb 2013 Posts: 5 | Oh cool!! I didn't know it had a place to put the studs. I haven't picked up the motor yet so I i haven't seen under the valve cover. Yes mine is a 207. Runs good but has a cracked block on the drivers side from being frozen in Oregon before I got it. I knew I would need a 235 valve cover. Mine is longer and a bit wider too. I don't trust this 207 for going on a long drive. It is fine for weekend drives around town but not much more. I am going to do a t5 with a full pressure 235 so I can drive it anywhere anytime. I am going to stay as stock looking as possible. Here's a link to pics of my truck: http://www.cardomain.com/ride/4010893/1936-chevrolet-c-k-pick-up/ thanks for the tips everyone!!! Ron.. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Jeff Ogden put a lot of work into getting the details right when he disguised a '57 235 to look like a 216 in his '37. > CLICK - "Going back to the basics in my 37"Unfortunately, his photos on Webshots were vaporized when Webshots closed their photo hosting site. Don't know if he has stored them on a new hosting site. Jeff is also "junkyardjeff" on VCCA.org Chat.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Ron, that is a beautiful truck, I must say! | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Hi Ron If it was me... I'd just swipe the studs and nuts while I'm swiping the cover.
Professional Novice
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I have gotten my 57 235 to look as much like a 216 as possible except for a fuel pump so if you want to see some pics PM me with your email address and I will let you see what I have done. | | |
