3 members (Shaffer's1950, Bill Hanlon, Gdads51), 96 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
Hello All,
I am in need of some help identifying this hole and part after I rebuilt a 55 235.
I took this engine to a machine shop and had it vatted bored, etc. Brought it home and put it together painted it and set it aside to finish the truck it was going in.
I received a call from the machine shop and was given this small part and was told it came out of the block. Can you help me identify where this part goes in the engine?
https://www.dropbox.com/s/colyh6otok5kqvg/IMG_3134.JPG?dl=0
Also, take a look at the second picture... there is a hole in my block between the fuel pump and breather tube hole... What goes there?
https://www.dropbox.com/s/h76y3ghp9vnjmg6/IMG_3133.JPG?dl=0
Thank you for all the help...
Dad and Son!
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
That is the baffle that is designed to prevent oil from splashing out the road draft tube. And yes it is held to the block by the hole pictured and another behind the road draft tube.
My Blog
Ok... Do I have to pull the camshaft to put the baffle back in or is there a trick to get to the bottom bolt...
Only the oil pan needs to be off.
The screws go in from the outside. They are sheet metal screws with a lead washer originally. I have had good luck using Nylon washers instead if lead if the lead washers are missing or damaged.
My Blog
Thank you for the update... I was able to get this back on with your help.
Hey Dave, do you have any pics or a description of the lead washers? I would like to try to make them. I am weird like that.
Carl
I will get back with pic's as soon as I get time.
My Blog
I have add a picture of the baffle, screws, and lead washers to my BLOG.
The lead washers are .190" ID, .350" OD, .040" - .045" Thick(hard to tell exactly as they are smooshed out from use).
My Blog
Thanks Dave. Is smooshed the same as squarshed? Or mashed? smile Lead was an interesting choice of materials for a warsher (yes , I say warsher) for this application. I cannot think of anything that would seal in the oil any better.
Carl
This area of the block is not spot faced so it is ruff from the casting. The lead washer conforms to this ruff area.
My Blog
Dave, where can a person buy the lead washers? Thanks Don
I think 52Carl is going to start making them for us wink
I know of no new ones.
When I can't find good used ones I use Nylon washers.
My Blog
Melt a wheel weight into a piece of 1/2" stainless steel tubing to make a lead slug, tap it out of the tube with a punch, then center-drill it and slice it off with a hacksaw into whatever thickness washer you need. I could use my lead bullet-casting setup to make some round lead slugs if anyone is interested in acquiring some of these washers.
Lead sheet & foil is still reasonably available in certain industries. Old school roofers often have some sheet around. If you know anyone in the X-ray or better yet the nuclear medicine / nuclear pharmacy fields they'll have all kinds of it.
Thin Pb sheet is really easy to work with -- can be cut with a utility knife. I think a reasonable washer could be fabricated out of an appropriate thickness of sheet by cutting the OD with scissors or a utility knife and using a cork borer or an office hole punch for the inside hole.
Pete P.
Harborcreek, Penna.
