0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Hung my front sheetmetal today and noticed that the fender brace rod will hit the carb. Anyone else dealt with this problem successfully? | | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | Hi Woody, I sent you a pic. of my 54 with the 2-1 carbs. Hope it helps | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Thanks Marty... I got the photo. That was my first idea but I thought there may be too much flex in the bend. I also considered moving the bracket that attaches to the fender back one bolt to keep the rod straight, but I'd have to make some measurements to get the correct length. I wonder how many guys have just left it off...  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here's a factory solution http://rides.webshots.com/photo/2098090740080251109GXrVzKI know it's not your truck, but it is an original 37 GMC. You could easily duplicate the idea to suit your truck, and even tell folks that's how GM did it.... Grigg | | |
