Neil, it's not a bad idea. When your compressor is pumping away, the air gets very hot and a basic filter will not get the water out very well. So, if you cool the air through the water cooler like you are talking about, then after that use a decent water and debris filter, you should be good. If you have a day or two, I can take a picture of my set-up, I have schedule 40 pipe near the ceiling, it runs about 25 feet from the compressor. There's a T, with a 4" nipple up, elbow, 2" nipple, elbow, and then a longer piece going down to the filter. So, the air goes up, then down into the filter, while the liquid stays down, and goes a few more feet, then out a ball valve. Confused yet? I'll take a picture. I'm sure you could find a diagram somewhere on the net.
