| | | Forums66 Topics128,075 Posts1,056,279 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, On my 59 Apache 1\2 ton what is the best way to get the pin with the screw end and the long pin that goes through the leaf spring out? It is on the front of the rear leaf spring any ideas would be great. Thanks Steve | | | | | Joined: Aug 2019 Posts: 242 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 242 | I found a bolt just small enough to slide through the middle, but long enough to press with (pirated from the autozone valve compressor tool), then found a piece of pipe big enough for the insert to slide into, and another pipe sized a little smaller than the insert for pushing it out. Cut the pipes to a convenient length, then slide the bolt through the pipes and the insert, get some thick washers and a nut then start cranking. The screw head kept twisting off, but after re-welding it a few times it worked!
'59 Chevy Suburban, NAPCO
| | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | Heat is your best buddy while working on springs ,
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks got them out not bad at all. | | |
