7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, 1 invisible), 67 guests, and 3 robots.
Topics128,056
Posts1,055,803
Members48,426
#912293 01/16/2013 7:37 PM
N
N Offline
i have a 56 Chevy pick and i got a problem and maybe someone out has an answer. the level reads full, around 60 psi. when i make a right or left it drops down to zero and knocks. is it time for a new oil pump? i just changed the oil and filter less than 100 miles ago[s][/s]
nate56 #912396 01/17/2013 7:07 AM
Something has happened with the oil pickup screen/tube.It probably fell off.When the oil is carried away from it in a turn, air enters the pump and it takes some time for it to reprime when the oil level returns to normal.
This will destroy the crank and bearings if allowed to continue.Damage may already have occoured.
Bob Taylor
nate56 #912426 01/17/2013 9:18 AM
N
N Offline
thank you for you help. i don't drive often i start it up daily,but it been over a year since she has been on the road. i will keep you posted. thanks again Bob. To 350 or 235 that is the question?
nate56 #912437 01/17/2013 10:09 AM
Red dot, center of chest ...
Whether 'tis nobler in the minds eye to keep the 6 cylinder or convert to the 8..... grin
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
nate56 #912455 01/17/2013 11:15 AM
You can probably economically save this patient at this point by just dropping the pan and fixing the pickup tube but a bearing inspection and replacement if necessary while you're there would be a good idea.
This should be a 235 with replacable insert bearings so replacement is not complicated.
Bob Taylor
nate56 #912475 01/17/2013 1:22 PM
N
N Offline
i was thinking about replacing the oil pump, but your idea sounds better.
