| | | Forums66 Topics128,172 Posts1,057,105 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I am starting to strip my frame on my 1950 1/2 ton to paint. I have a small 20 x 20 garage so my space is a premium. It starting to feel a bit overwhelming with such little room (not sure where to put the cab)but I've seen guys do more with less than I have. How did you guys paint your frames? In order to be able to rotate it to paint both sides I would have to get it pretty far off the ground to be able to make the rotation, mainly because the running board brackets stick out to far. Can someone post pictures of how they painter their frames? Did you paint top and bottom side one at a time?
Thanks, skipper | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I used a small detail HVLP gun and a creeper to shoot the underside. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Frames are not that heavy. Put it up on solid sawhorses. Have a friend help you flip it over. Do the underside first except for the front and rear crossmembers. Flip it back and do the rest of the frame including crossmembers,top and bottom. It can be done in an hour if your frame is clean.
Drew
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Can someone post pictures of how they painter their frames? Did you paint top and bottom side one at a time? Heres Deves web site with some pics Deves web site I have a 3 car garage and quickly ran out of space. Pic. I was able to move my cab around with just that garden wagon in that first pic. The cab in not that heavy. I just rattle can painted my frame. I was just going for some protection. Not showroom results. Where I live there is no conern over rust. Good Luck | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Very clever guys! I like the rotating idea but I would have to buy engine stands. I think I can make sturdy enough saw horse stands to hold my frame. What does a frame weigh?
thanks, skipper | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Look into power coating your frame.cost less then you think' a little over $100.a shop in Akron, Ohio.do power coating .the price is as said above.Those Cal folks are ripping a new hole you know where.
dan-pa
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I wired wheeled my frame down. Afterwards I wiped it with thinner to clean it. I then used Eastwoods rust converter and then Eastwoods Rust encapsulator. Afterwards I gave it a light scuff and then hung it outside on my engine hoist. I sprayed it with Rustoleum Industrial semi gloss black. It looks awesome. Not perfect, but awesome. I wanted to have my frame sand blasted and powdercoated, but the cheapest I could find in my area was around $750. I did my whole frame for $110 and my labor. Another good thing about the Rustoleum is it is very easy to touch up if and when it gets scratched. Here is a photo, check my album for the whole process. http://good-times.webshots.com/photo/2210667530031183259EWUKXl
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Wow, your frame turned out fantastic. A few questions, the rust converter is that like a product called Metal-Prep? Metal-Prep turns metal a yellowish color once it is washed off. How many quarts of the rust encapulator did you use and did you brush it on? Did you have to do anything special to the encapulator to get the Rustoleum top coat on it?
Thank! | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Metal prep is different than the rust converter. After you apply rust converter you do not wash it off, it stays on.
I bought only one quart of the rust encaspulator, and have plenty left over. That stuff covers very well. I applied it with a foam brush, that made it real easy to get into all of the cracks.
Once that cured, I lightly scuffed the whole frame with 320 grit sandpaper, blew off the dust and I was off to the races with the Rustoleum.
Frame looks great, and it is easy to touch up scratched during reassembly.
