7 members (Tronman, Dennys28, 39Master85, dt235sd, carbking, kades51, 1 invisible),
58
Mod | | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Considering the possibility of a future need to remove the pan I might be tempted to bust the rivets and bolt it back.
~Jim
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | All the frame cross members are probably the only riveted frame members that I would be hesitant to bolt together. I would think to resist frame twist, the cross members need to very securely fixed in place. Bolts might allow movement. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | GM chose to bolt-on the rear motor-mount frame cross-member and the rear transmission-mount frame cross-member on 1954/55 1/2 ton Hydra-Matic equipped trucks.
On other 54/55 1/2 ton trucks, the rear motor-mount frame cross-member was riveted on, and there was no rear transmission-mount cross-member on manual transmission equipped trucks.
If movement was not an issue with H-M equipped 54/55 3100s, most likely bolting earlier (47-43) riveted cross members would not cause movement problems?
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | John:
Very interesting color...will stand out for sure. Why not paint the transmission the same color while you are at it? It seems that is what they do on all the quick build car shows like OverHaulin, etc. Good progress. I'll be painting the underside of the cab that same green color and with the black tranny it will stand out more (at least in my opinion) with the polished aluminum deep pan and flex shield.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
~Jim
| | | | | Joined: Jan 2013 Posts: 26 New Guy | | New Guy Joined: Jan 2013 Posts: 26 | What did I do on my bolt? I have a lead on fenders for my 54 1Ton. happy happy happy! Go and see them tonight.
Well that was worth it! I now have 2 fine fenders for my beat up 54. and lovin it!!!
Keep on Rollin!
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Ordered my drop axle kit from SID!!!!! | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | slapped in a new generation inline 6, the Chevy 230 last night. Need to finish hooking it up now! | | | | | Joined: Dec 2012 Posts: 78 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 78 |
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Added a cig lighter socket so I can charge the cell ph. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Got new tires. 255/50r17 nitto in front, 305/45r18 in the rear.
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Red Ryder wants Quads sooo bad. He's just gonna have to be happy with the new Edelbrock air cleaner he got for Christmas! pic
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Took the front axle out today, ready to pack it up and ship it off to Nostalgic Sids! Came out rather easy i was surprised at that | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | Picked up the new motor for the 37 today,its a shame the rebuilt 235 has issues but this time I am going with a good used motor. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I should have fixed the front right side running board bracket and replaced the rear main seal but instead I took it on a nice 100 mile cruise. I guess I'll fix those later  | | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | I took apart my original Rochester Monojet carby and cleaned it ~ filthy and had several big vacuum leaks .
These are terrific carbys having a metering rod you can adjust and aluminum bodies so they last and last .
Lucky for me , this one had never been overhauled by those ham fisted boobs who chuck carbys into the bead blast cabinet....
It's done but I have other under hood & engine things to address before re installing it .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Had a good weekend of work (wife out of town): installed headliner, sun visors, windlace cab and lower cab windlace rubber, windshield trim metal, a/c vents, fuse block (for added accessories), hard fuel and vacuum lines, battery cables, carb and related cables/controls. And, a few other small odds and ends. But, the cedar pollen was kicking my backside the entire time! | | | | | Joined: Jun 2012 Posts: 39 New Guy | | New Guy Joined: Jun 2012 Posts: 39 | Ended up removing the front motor mount bolts and loosening the rears to lift the engine - no problem slipping the pan out, cleaned and repainted after that. Now, getting the engine mount bolts to line up again on install...that was another challenge
Rick in San Diego (...er, Jackson) '66 FleetsideOl' Car Guys"I was born in the back seat of a Yellow Cab in a hospital loading zone and with the meter still running. I emerged needing a shave and shouted 'Times Square, and step on it!'" - Tom Waits
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I sand blasted a few parts ,and ordered a cam from Howard cams. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Now, getting the engine mount bolts to line up again on install...that was another challenge  Just put a 230 in my 54... i know what youre talking about. Took forever by myself | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Nothing but awesome!!
Really enjoyed taking the photo tour of your project.
John in Raleigh, NC | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I swapped out the gas gauge and ammeter. I also installed the fresh air heater, need to hook it up still. | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | Did nothing to the truck but spent some time on the computer trying to find out what a correct fan for the motor looks like,I have a 49-54 car fan on it and there is only 1/4 inch between the fan and radiator. If I would have to change a fan belt on the road I would be screwed as I do not think I could get one on,I do not think I can remove the fan without taking the water pump off with it so it might have to get changed when I install another 235 in it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I had a 57 with a 235 that was like that, just used an open end or box wrench to remove the fan, tedious to change a belt, but how often ya gonna do that?
Bill | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I found a fan on ebay that looks like will give me another 1/2 inch,this fan looks identical to one that was in some pictures someone with a original 37 posted on the VCCA forum. | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | Since I do not have the throttle rod coming up to the carb I made a little bracket to attach the throttle cabe to and bent a extra throttle/choke cable bracket so it would work. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Connected choke and throttle cables to carb. Routed/measured all a/c hoses so I can get ends crimped on. Worked on seemingly miles of wiring for added accessories: a/c, electric condenser fan, radio/speakers, subwoofer (under seat), turn signals, cigar lighter, and PA system. I added a fuse block and terminal board for all added circuits and a dedicated ground circuit from frame/engine ground strap to terminal board under dash. The positive side of terminal board is energized via a heavy duty 30 amp relay active from accessory post of ignition switch. The cigar light is always hot via the light switch battery post. This way, I don't put a large load through the ignition switch. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Finally got the fresh air heater all nicely bolted in place. It took a bit of prying and levering but it finally fit. Hooked up the coolant hoses, vent hoses, sealed up the motor/firewall. I tried out the motor, nothing. It worked perfectly on the bench. I had to walk away from it, at least for now. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Try a ground wire from a motor bolt to a good ground. My units did not have a ground wire, but I saw a ground wire on New Design GMC units (from the case to a screw in floor or dash?).
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Looks really great!
Just about to do both of those myself. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Nice work. I like the detail photos on your steering wheel. I think they give good reference for someone who has never done that project.
Drew
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Nice work Bob, glad to be of a help to you. Stay Warm, Mike | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I took my heater back out, the wire to the one brush was disconnected inside the motor housing. Got everything back together and installed, goes much faster the second time. | | |
