| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Hi - The book calls for a spring on the shaft(on bellhousing) for the shifter linkage bracket on my 50 with 216 3 speed. Does anyone have a picture of this spring and/or know where to get one? Thanks! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If you are referring to the tension spring along with a washer and cotter pin, I bought replacement springs at my local hardware store. Sorry, no pic.
Drew
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Are you talking about the bell crank for the 2nd and 3rd control rods? What book says that there is a spring there? I don't think mine has one. Carl
| | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I am referring to the pivot for the control rods. This mounts to the bellhousing. I have the special clip and washer for this but not the spring. The assembly manual calls it out in section 7, sheet 2.00 and calls it out as spring #3698237. If I were to guess, its 1/2" I.D. and maybe 1/2" - 3/4" long when installed. | | |
