8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
1 Offline
Hi - The book calls for a spring on the shaft(on bellhousing) for the shifter linkage bracket on my 50 with 216 3 speed. Does anyone have a picture of this spring and/or know where to get one? Thanks!
If you are referring to the tension spring along with a washer and cotter pin, I bought replacement springs at my local hardware store.
Sorry, no pic.
Drew
Are you talking about the bell crank for the 2nd and 3rd control rods? What book says that there is a spring there? I don't think mine has one.
Carl
1 Offline
I am referring to the pivot for the control rods. This mounts to the bellhousing. I have the special clip and washer for this but not the spring. The assembly manual calls it out in section 7, sheet 2.00 and calls it out as spring #3698237. If I were to guess, its 1/2" I.D. and maybe 1/2" - 3/4" long when installed.
