1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | OK I am going to ask this question a different way because I am in the dark!
I'm building a '50 3100. I have a '61 235 complete with bellhousing, flywheel, starter, etc.
I need to use the 216 bellhousing I have to mount the engine to the frame.
So...how do I take off the 235 bellhousing and replace it with the bellhousing from the 216 but still use all the guts of the 235 bellhousing? I'll need to find all the parts for the mechanical clutch assembly. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | From the 1961 235: You take off the clutch assembly. Then, you take off the flywheel. Then, you take off the clutch housing (bellhousing).
You might want to put into the 235 a new pilot bushing.
You then put onto the 1961 235 engine: The 216's clutch housing. Then, you put on whichever flywheel suits your tastes (6v 216's vs 12v 235s) Then you put on the clutch assembly that matches up to the flywheel.
Be sure to use the throw-out bearing that matches the clutch assembly.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Make sure you read Tim's line about the flywheel. You need to determine if you are staying with 6 volt or going to 12 volt. That determines which flywheel to use. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Right, so if I am going 12 volt, I use the flywheel from the 235 (and thus can also use the 235's starter)?
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I'm sorry put in just for other folks that are novices, wouldn'tthe bell housing must come off the engine first, then the pressure plate must be removed to get the clutch disc out of the way in order to get to the flywheel bolts for removal of the flywheel- in that order. Don't mean to poke holes in the thread here but it needs to be spelled out for the youngsters that haven't worked on these engines before.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | You can not take the bell housing off, without removing the clutch and fly wheel first. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Right on 31-33. There are bell housing bolts behind the flywheel SS, so it all has to come out before you can get to them. and you're correct, it does need to be spelled out for the youngsters that haven't worked on these engines, lets not cornfuse them. Also Jr, I don't think it was mentioned or made clear, that you could also use the 216 flywheel with the 216 starter if you wanted to, even if you're converting to 12v. DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Ya that makes sense.
But I have none of the parts for the 216, just an empty housing.
So I'll need to use as much as I can from the 235 and find the clutch fork and assembly somewhere. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The parts book shows the clutch fork fitting: 1940-54 pass, and 1947-59 6 cylinder truck. Group 0.795 Part#609954 or 839240 eBay sample
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | You can not take the bell housing off, without removing the clutch and fly wheel first. I see, not like a smallblock chev then. This is when learning really takes place. Thanks all for the clarification and Tim for bringing this to light.
