7 members (DadsFirstPickup, Otto Skorzeny, baldeagle, Youngin' Tut 59, 51sub, asilverblazer, Gray_Ghost),
49
Mod | | | Forums66 Topics128,180 Posts1,057,146 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 70 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 70 | I think I need to rebuild the carb on my little Jimmy. It's the original 228 w/the zenith carb. When you hit the gas it falls flat on its nose, you really have to ease into giving it the pedal. I have a rebuild kit for it already (PO must've thought it needed rebuilding cause it was under the seat when I bought the truck). I've never rebuilt a carb before but I really would like to learn how.
This carb appears fairly simple- seems like a good place to start learning. Anybody know of a good set of instructions or YouTube type video that shows it? I don't see one for zenith specifically - will another brand give me a good enough idea of the basics? Thanks for any advice- Greg
1951 GMC 250 Open Express 1968 C10 Suburban 1971 C20 Pickup
My Dad told me "Son, never hit a man in anger- unless you're certain you can get away with it"
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Go to Mikes carb it has a lot of how to videos.It's on U Tube.
Pete
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Carbs are fairly straight forward. If you have a camera phone I recommend pictures during the process. If ya get confused it enables you to look back in time at the carb throughout the process.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Ditto on Mikes Carbs, great to purchase kit from too Jerry
| | | | | Joined: Jan 2011 Posts: 70 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 70 | Looks good, thanks guys- Mikes seems to be a good video. I'm gonna give it a shot.
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I watched his video. There are passages that should be cleaned. They are sealed with a lead BB that is drilled out and reinstalled after cleaning. Also, it looks like he fails to address the check valve on the accelerator pump. That is one of the first things to fail on a Zenith. | | | | | Joined: Jan 2011 Posts: 70 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 70 | Thanks crenwelge. I see he mentions ultrasonic cleaning but doesn't show that step- do you think that would take care of the passage? Also, what is the common failure on the accel pump? Something in particular that I can look specifically for- I need to lay out my rebuild kit and see if there is something in it for that. Thanks again- Greg
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | There is a pressed in check valve that has a brass disc in it. Most kits don't include it and care must be taken in installing a new one. Here is a name of a guy that is very good on Zenith Carbs. Larry Isgro Carburetors Inc 1604 Argyle Road Wantagh, NY 11793-3144 (516) 783-1041 If you want it done right, I would give him a call. I have been fooling with Zeniths for over 50 years. I don't even want stinky carburetor cleaner around any more. But If I had a Zenith that needed repair, I would Larry do it. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | The 228 is a 28 with the choke linkage 90deg off from the throttle linkage... so any Zenith 28 Series carb manual will cover the rebuild.. Here's a free factory manual.. http://ebookbrowsee.net/zenith-28-128-rebuild-manual-pdf-d387424874Good scans.
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Today I received a quote from Treadwell Carburetors for that "check disk" - $21.00 ea.!!! It's smaller than my pinky nail, and each Model 29 carb I work on has two, which are destroyed during removal. That we know of, they're only available still from Zenith. Sheesh!
Work to the wise: check the operation of the check valves, and if they pass, don't touch 'em!!!
-Michael | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Three places to get Zenith rebuilding kits that include check valves
carburetor-parts.com Mikes 43.95
carbkitsource.com 64.00
carbkits.com 74.00
Mikes has a how to video you can watch after you click on the rebuilding kit for the 28/228 kit.
I made a tool to install the valves out of a 1/4 inch socket the top one is easy but the bottom one is a little tricky.
Pete
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Look for the G508 rebuild kit.. they are $30 on ebay and include all the parts. Since they are milsurp they include all the parts. I rebuilt mine and got the check disk out with a drywall screw. http://www.tm9-801.com/forums/viewtopic.php?f=1&t=468You will need to log in to see pictures. Its not a true step by step, but I do talk about the check valve. | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I have done a mess of those carbs and have the check discs if you need one. Shoot me a PM or call at 540-955-0479 Depending on which one you have you just lift the tabs and the disc will fall out. Some have to be drilled and pulled with a small slide hammer, those will need total replacement. oj
A shop is where you wash your hands before you pee.
