1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Hey guys - I have what appears to be 3 layers of paint over the aluminum ID plate located on the driver's side post. I'm not sure what paint stripper will do to the black on the aluminum. Any advise?
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
Originally Posted by DADS50
My plate was painted over also.
You can see it in this pic Drivers door jam painter over.
I was able to take the paint off with a razor blade ID plate pic After the razor blade I cleaned it with some thinner and a rag
The original plate is silk screened I think.
Only a little bit of the edges came off.
The S/N is stamped on the plate.
Good Luck
Thanks Gus. I will give this a try. I've accomplished much with the help of your detailed photo documentation. Much appreciated.
Scott
72 Chevy K20 - DD
