0 members (),
99
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 5 New Guy | | New Guy Joined: Jan 2014 Posts: 5 | we just came across what was sold to us as a '46 but we're having problems verifying that...
i have confirmed the engine to be a 216 via the casting stamp, and have managed to find a bundle of number on what was left of the "vin" plate..... they are as follows
58 - lower half center of plate 2 5727 - left hand side of plate 9BL41 - bottom center of plate 5092 - bottom right hand corner of plate
any information would be greatly appreciated!!
| | | | | Joined: Jan 2014 Posts: 5 New Guy | | New Guy Joined: Jan 2014 Posts: 5 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | 41 and 46 trucks had chrome grills, etc. Looks like you might have a 42 or 45, but it's hard to tell from the pic. I don't know the vin decoding for american trucks, but someone will chime in. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Need more pictures of the truck itself. Casting # on engine block would help identify the date of engine manufacture.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jan 2014 Posts: 5 New Guy | | New Guy Joined: Jan 2014 Posts: 5 | the casting number on the engine was 839910.. which means '42-'51 from what ive been able to find. directly to the left of the distributor was a boss with a weird stamping picture i have measured the axles and did find it to be 125 inches so i believe it is a 3/4 ton
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Listed in 1942 http://chevy.oldcarmanualproject.com/chevyresto/4206.htmVehicle Prefix: 9 = Norwood, Ohio assembly plant BL = 3/4 ton regular Engine stamping: BF one ton, Heavy duty & School bus
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jan 2014 Posts: 5 New Guy | | New Guy Joined: Jan 2014 Posts: 5 | Thanks Tom!
so am i to assume that the engine is not original to the truck since it was stamped BF for 1 ton-HD and the truck is a 3/4? or would it be possible that it was made with a HD engine in it?
another question i have is about the bed. it has a metal floor in it.. would that have been an option in 42? i assumed that it should have been wood slats? | | |
