4 members (Maybellene, klhansen, 2 invisible), 87 guests, and 3 robots.
Topics128,211
Posts1,057,468
Members48,471
Billo57,this is what I came up with when I was asking the same question.
1947-1955.1 seat Look at the curve on both sides of the seat rear sheet metal.
1955.2 to 1959 seat Look at the curves on the 1955.2 to 1959 seat,no square part to it.
Ive noticed the seat cushions are built differently between the years 1947-1955.1 . same shape and size,just built differently with the springs and wire.
Ive also noticed the seat cushions are built differently between the years 1955.2-1959 . Same shape and size,just built differently with the springs and wire.
That being said,just recover the 55.2-59 to to whatever you want.They will work,no problems.
The front seats are the same as well.
Jim Carter told me the 55.2-59 seats are more rare,due to more of those years were crushed. I don't know if it's true or not.But i do know Ive seen more 1947-1955.1 suburbans than 1955.2-1959 suburbans.
My photobucket album has a lot of pictures of seats as well.
Hope this helps you.
Tim
1951 3100 Chevrolet
Thank you sir,
'Be pretty tough venturing out in uncharted territory regarding a project, if fellas like you weren't willing to share.
Again, thanks so much for your time and info. I hope at some point, putting that freely given time and info into something tangible.
Thank you for your reseach and sharing
52 suburban
48 Palace
So 1955 to 1959 Suburban middle and rear seats will fit the stock mounting holes? same for the width of the suburban?
