0 members (), 170 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#997316 01/06/2014 7:36 PM
I have a 59 truck and onder the dash are two vents to send air up to the window. I recently got a trim piece that goes between the window and the dash. Should there be slots in the trim to let the air flow up?
no slots, the trim piece stands off just enough that the air from the vents is directed on to the windshield full width, attached with a screw on each end and some clips along the length [forget how many, just a few]
Flxible #997365 01/06/2014 10:15 PM
What he said!
Thanks. i have the clips . must be a loose fit.
I managed to save a couple of my old clips. I got a set of repops, I have not had time to compare them yet.
I have been wondering if I will be able to measure the distances and have them all in the correct position, when I start to pop it in. Also doing this without scratching up the new paint on the dash.?
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
the position of the clips isn't critical, they slide around freely, easy enough to put that trim piece on - even without the clips
Thanks, Bill.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Classic has them
http://www.classicparts.com/1955-59-Windshield-Trim-Fasteners-Screw-Set/productinfo/32-121/
Once in the trim peice, start in the center and slide them to line up with their holes and then starting in the center just gently push them in working your way to each side. Finish with the 2 screws.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Thanks for the tip!
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
