| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I have a 59 truck and onder the dash are two vents to send air up to the window. I recently got a trim piece that goes between the window and the dash. Should there be slots in the trim to let the air flow up? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no slots, the trim piece stands off just enough that the air from the vents is directed on to the windshield full width, attached with a screw on each end and some clips along the length [forget how many, just a few]
Bill | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | no slots, the trim piece stands off just enough that the air from the vents is directed on to the windshield full width, attached with a screw on each end and some clips along the length [forget how many, just a few]
Bill What he said! | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Thanks. i have the clips . must be a loose fit. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I managed to save a couple of my old clips. I got a set of repops, I have not had time to compare them yet. I have been wondering if I will be able to measure the distances and have them all in the correct position, when I start to pop it in. Also doing this without scratching up the new paint on the dash.?
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the position of the clips isn't critical, they slide around freely, easy enough to put that trim piece on - even without the clips
Bill | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 |
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 |
