Brrrr
place holder
8 members (Peggy M, klhansen, Charles in CA, Hush, Nick in Manitou, 41 chev, Bucker, 1 invisible), 179 guests, and 4 robots.
Topics128,270
Posts1,058,408
Members48,485
#995535 12/30/2013 4:04 AM
so if someone decided to swap the axles in a 4400 to a more common dually 8 lug does that mean its not really a big bolt anymore? wouldn't that lower the gvwr but lighten the truck so would it really make a difference. opinions suggestions. pictures. i like the idea of running big rig wheels and tires. keeping kind of original looking. the 8 lug to 10 lug adapters are ugly and clutter a full floating axle.
If your truck you can do what you wish.
What are you really asking?
•1952 Chevrolet 3800 pickup
---All pictures---
You (and everyone else) are welcome to participate in any of the Forums here on the Bolt if that is your concern. It's your truck so you decide.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
When you say more common, do you mean more modern, or more common like your average one ton dually?
If it's a modern axle out of a newer 1.5 ton or larger truck, that would still make it a big bolt.
If it's one out of a one ton dually, I wouldnt consider it to be a big bolt anymore, in my opinion.
If you are looking to go with a more modern axle & keep the heavier load capacity, do what Grigg did, I believe he went with modern axles with disc brakes & kept it as a big bolt. The beauty of the modern axles, is you can also use modern wheels.
Im kind of wanting a daily 1.5 ton. An overall work truck but I want to go 4wd cause I can. Problem is a 1.5 ton steer axle. The Dana super 60 is what is used on the f550 front axle but its hard to find and stupid expensive. I found a 4wd 1.5 ton fire truck but I don't know if I want to buy another truck for the axle. Unless price was incredible.
I'm looking at a similar 4x4 conversion. I've pretty much resigned myself to 8-lug due to availability. Keep in mind that these trucks only had about a 10,000 GVWR, which is about the same as a modern 3/4 ton truck. I think modern 1-ton axles should give more than adequate payload.
Also keep in mind that front springs on your truck are probably about 10" closer together than a modern truck which will definitely cause issues.
An AD 2 ton is usually 16,000lb and 14,000lb for a 1.5 ton
---All pictures---
OK, looking at the specs on my '41, the GVWR is between 7700 and 14,000 depending on options. I would still put that in the class of a modern 1-ton DRW truck.
Looking at this , I'd say a Dana 60 front axle should be adequate for a front axle assuming you appropriately sized springs/wheels/tires.
That chart might be for rear axles only, a front Dana 60 May have a different GVW rating. Dana would be a better source for that info than Wikipedia.
Also a big factor on axle ratings are the brakes. Same axle can have small or large brakes and differing ratings even though wheel bearings and other weight supporting parts are the same.
When you say "modern" how new is that? In the last couple years 1 ton pickups are similar capacity to our old 2 tons. But several years ago that was not the case. For example my truck is now on axles from a late 80's P30 or 3500HD which have about a 14,000 lb GVW. Those are/were a nominal 1.25 ton at best, a heavy 1 ton, not considered 1.5 or 2 ton, so that era 1 ton is certainly not comparable to an AD 2 ton at 16,000 lb. I still call mine a big bolt.
Still not sure what the question is or why it's an issue?
We can all build our trucks to suit our different uses and call them what we want. Only trouble comes when overloading components, so use strong enough parts for how you will use the truck.
Grigg
---All pictures---
A dana Super 60 is larger than a standard 1 ton with a higher gvw. its a 10 lug axle that they put on F450 and F550 trucks. Bigger brakes for a higher gvw. I personally love the 10 lug but I hate the look of the 8 lug to 10 lug adapters. too cluttered. I want to keep the gvw the same if not a little more to compensate the additional weight of the front axle and motor.
Ring gear measures 9¾".
3.125" diameter axle tube.
Weighs in near 500 lbs. More or less depending on width and brake configurations.
OEM Inner axle shaft spline counts are 16, 23, 30, 32, 33 and 35.
40 Spline inner axle shafts and carriers are made for after market, high performance Dana 60 axles.
Pinion shaft diameter: 1.625"
Pinion shaft splines: 10 and 29
Gear ratios: 3.31:1 - 7.17:1
Carrier break: 3.31:1 - 4.10:1 and 4.56:1 - 7.17:1
Axle Shaft diameter
1.41” Front (32 Spline)
1.46” Rear (32 Spline)
Axle spline diameter
1.50” Front (35 Spline)
1.50” Rear (35 Spline)
1480 Universal Joint (Front axle)
Brakes measure 13.66" for 2011 F-250 & F-350 trucks.
Brakes measure 14.53" for 2011 F-450 trucks (13,050 GVW).
The Dana Super 60 is an upgraded version of the Dana 60 front axle.
Differences in the Dana Super 60 versus the regular Dana 60:
Larger and thicker diameter steel tubes (3.75 inches diameter and 1/2 in thick)
Larger ring and pinion which increase the contact area and overall strength.
Larger Universal Joints which increase strength and steering angle.
Super 60s use 1550 Universal Joints.
Net formed spider gears for increased strength.
All made with 35 Spline axle shafts.
This axle was used only as a medium duty unit until the Third Generation F-450 Pick up began production. The Third Generation F-450 pick up is a light duty truck. This axle is still used in the medium duty F-450 and F-550 4×4 trucks as well.
Why not try a 11.5" 14 bolt? The off roaders are converting the 10.5" 14 bolts into steer axles. The 10.5 and 11.5 use the same axle shafts and tubes.
The modern 1 ton trucks are more capable than any 1.5 ton stovebolt, so it would be a good swap.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
The 11.5 ring 14 bolt could work but its 8 lug. I've seen the 14 bolt steer axles and I was looking at that but once again 8 lug. If I can figure out how to make them 10 lug. I may try to get another ho52 or ho72 or whatever came in these trucks and build a steer from that. It would look more like a "factory" option.
Crusing in the Passing Lane
All that matters is spindle OD and length. Lots of axle shaft options and people that hob custom shafts.
Perhaps 10 bolt hubs, backing plates, brake drum/disc could be made to fit in 8 lug spindle(bearing spacers, different bearings, etc?)
I did some research and it seems the Super 60 axle is meant for the f550 trucks, which is way more than enough for your truck. Not to mention it's a 10 lugger. http://www.fourwheeler.com/how-to/transmission-drivetrain/131-0906-dana-super-60-front-axle/
Another option is the Dana 70 front axle. It was used in Kodiak trucks. http://en.wikipedia.org/wiki/File:DANA70HDKodiaks.jpg
On the other hand, the rear hubs from a Dana 60 or Dana 70 will fit the 14 bolt with the appropriate bearings. So it may be possible to use a 10 lug hub from a F-series. I'm not for sure about the hubs on the Sterlings axles, I would assume they're the same.
There's always this option too. http://www.boyceequipment.com/#!rockwell-25-ton-axles/c1so0
Chris
"The Fake Truck"
O.k. my ADD is getting the best of me. I looked up the bearings for Ford Sterling, Dana, and 14 bolt. Looks like the all have the same shaft size. Eaton rearends, however are roughly .060 larger.
I measured my Eaton axle, it is 3.25 diameter. So, using a C from another axle, it may be possible to convert an Eaton to a Steer axle. Which would be an interesting combination.
http://www.reidracing.biz/off-road-products/dana-60-knuckles
http://77cj.littlekeylime.com/flatop_knucles.html
"The Fake Truck"
well whitedog thanks for doing the research for me. lol. I do rock crawling for fun so i have dabbled in the 14 bolt steer axle. if i kept the eaton axle i think it will be very unique and look more factory.
