| | | Forums66 Topics128,118 Posts1,056,302 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Putting the front end back on my 53 3100 and am a litle confused amd have a few questions. 1st The panel that holds the hood latch and bolts to the radiator support has 2 holes in the top center but nothing to bolt to. Am i missing a piece that might go across the top of the radiator support. The p.o. installed a 235 and i assume he moved the radiator forward a little because the hood latch panel had been cut and folded upwards along the top across the radiator for clearence. 2nd Am i supposed to have an x brace on the radiator. It did have 2 that went to the bottom pan but not sure where they bolt onto. And finally Is it ok to install the grille first then the bottom splash pan after that. Thanks for any help. | | |
