4 members (Charles in CA, IHPWR, Otto Skorzeny, 1955 1 Series), 155 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#995485 12/30/2013 12:39 AM
I have a Delco Remy Generator and am trying to find out the specs of it.
Model # 1100018 ser # 2m24
Can anyone help me with the info on this and a regulator for it or point me in the right direction?
The model number doesn't have enough digits. For instance, a 1952 Chevrolet 6 volt 30 amp generator model number is 1100013. Are you sure you've copied the model number off the tag correctly?
My bad, I missed the first "1" (covered by paint).
I corrected the original post.
Here's a reference to that model number:
1953 Chevrolet 235 (108 hp) Inline 6 Engine Generator Specs
www.secondchancegarage.com/public/...6-generator-specs.cfm Cached
DELCO-REMY GENERATOR SPECIFICATIONS. Generator Number: 1100018, 1102793 (generator rotates clockwise) Generator output: 1100018 ...
It's listed as "obsolete" by Delco-Remy, not surprising since it's a 1953 6 volt truck item with a 45 amp output by the information I've been able to find. That would make it a heavy-duty unit, as most 6 volt GM generators were either 30 or 35 amp items. To get the full charge current output, most of the regulators available these days would need to have the current regulator adjustment increased by about 10 amps or so. Not difficult- - - -just a spring tension change to the center coil assembly under the regulator cover, but the technician doing the adjusting needs to understand how to load the battery to get a correct current regulator adjustment.
Thanks Jerry...
