| | | Forums66 Topics128,163 Posts1,056,920 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Howdy! I am going to be replacing the roof skin on my 57 here in the next few weeks due to rust, would it be a good idea to put some of that sound dampening/ heat shield mats on the underside of the new skin to help reduce noise and heat? Or could I put it on the topside of the inner roof panel? I live in south Texas so 100 degree weather is a norm during the summers, thought that these might help but not sure if its worth it.
Any thoughts on this?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sure, any thing would be better than a large thin relatively flat outer panel. Even a small pad applied to the center of a flat panel such as the roof or door will dampen out any drumming that would occur there. Don't know about your TF but the AD's had a pad of heavy felt paper stuck to the roof to dampen out drumming. It was common in most later vehicles on the back side of the door skins also. DG
Denny G Sandwich, IL
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The more you do on the interior the more comfortable your truck will be. I have friends that have done their whole interior and even used tape to seal the seams. It will be more than worth the time and effort to do it. Don | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | That's what I was thinking. Do yall have any suggestions on what to get, any brand better than the others?
Thanks | | |
