I am not sure on how big the difference is because when I bought my truck the motor was stuck. I just replaced the old ignition and points and replaced it with the mini HEI. If you do not want to make one as in the tech tip, here is where I got mine.
Mini HEI This unit is based on G.M. 2.8L āSā truck 1982-1984 and uses cap, coil, rotor, module, pick-up coil, and vacuum can from this distributor. The optional round coil is typical Ford electronic ignition 1977 to 1984
