5 members (mason86, Oldcaliforniakid, Wally / Montana, Gray_Ghost, 1 invisible), 114 guests, and 0 robots.
Topics128,068
Posts1,055,883
Members48,428
#994991 12/27/2013 11:49 AM
I would like to know, can a single rod be removed while the engine is still in the truck and head is not removed?
My though is you remove the bottom rod cap, turn the engine until you can swing the rod out of the way, pull the rod and piston down so the skirt is exposed, loosen the clamping bolt on wrist pin, and slide wrist pin out of piston, and finally rod falls out? Thanks
1953 Chevrolet Handyman Wagon 36k
1938 Buick 38k
1947 Hudson Commodore 18k
bigblack'74 #995040 12/27/2013 6:34 PM
Crusing in the Passing Lane
I'll bet it cannot be done, wrist pin has to go out somewhere. If one rod is bad? might be well to pull head and do it right, check them all, do rings, touch up valves, add 9
:1 pistons, new head gasket, etc., then one knows what one has.
bigblack'74 #995074 12/27/2013 10:04 PM
Riding in the Passing Lane
Most of the 6 positions can be done exactly like you said. I did #1 on a 216 many years ago.
1972 Chevy c10 Cheyenne Super
Thanks that's what I needed to know!
1938 Buick 38k
EdPruss #995107 12/28/2013 12:45 AM
I'm willing to bet that, with all of the old Chevy trucks he has listed in his post, he knows pretty much what he has. And that would likely be an old motor that refuses to quit running but needs a little something to keep doing so. With the long list of trucks that this guy has, he probably doesn't have any money left to do a total rebuild. Shouldn't there be a legal limit of how many old Chevy trucks a guy can own. You're hogging them all, man!
Carl
bigblack'74 #995109 12/28/2013 12:56 AM
Rods got changed that way for many years. I think there's just enough room to change a 216 rod - - -235's have too big of a bore for the piston to drop far enough to expose the wrist pin at the bottom of the cylinder. Even with the clamp bolt loose, it's difficult to get the pin to slide through the rod- - - -be VERY persistent, shaking the rod front to back in the piston very vigorously. The boss at the first shop where I worked other than the family business had quite a colorful vocabulary when he was changing 216 rods from the bottom side!
bigblack'74 #995128 12/28/2013 2:53 AM
Reading this post makes me want to pull the pan on one of my spare 216's and pull the rod out and then put it back together. I'm curious about getting the pinch bolt tightened without twisting the beam of the rod?
Don
don stocker #995134 12/28/2013 3:10 AM
Don
As I recall, the boss in that shop used an air impact wrench with a flex socket and a long extension- -just bumped the trigger a time or two to loosen or tighten the pinch bolts. Not the most accurate method, but he did a lot of business changing 216 rods from the bottom. I guess it worked well enough!
52Carl #995177 12/28/2013 11:55 AM
Carl
You hit the nail on the head. We use these trucks everyday and there is no time for a rebuild at the moment.
1938 Buick 38k
bigblack'74 #995187 12/28/2013 2:29 PM
I removed a head on a 235 a mo. ago in a couple hrs, and wasn't in any hurry , if it had a bad head gasket , I could have did the whole job in less than 6 hr. and I think that's v. conservative . and in 4 days I'll be 70 yrs old...just me , it makes since to remove the head ..we already spent 24 hrs talking about it .....probably has more damage than a rod ....
Good luck let us know what u do ....
" STUCK IN THE '50'S "
