| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I'm getting ready to install a rebuilt heater in my 56 pickup. It's the original style round core. I can't find any diagrams in the manual on the heater and was wondering if someone can tell me which hoses go where. The core has an upper and a lower pipe when viewed from the engine compartment. Thermostat to upper? Thermostat to lower? Thanks for any help.
1956 Chevy 3200
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might not matter, but the accessory manual shows what the factory did, stat to lower Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Is that cause heat rises Bill?  I just said that cause my round core has no control valves to mess with so I see no difference but its good to see the manual link... Thanks
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | My heater has no controls either.Thanks for the response.
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | probably more important with the deluxe style heater, but I wonder if the flow is to or from the water pump [cooler] OR to or from the stat housing [hotter]  Bill | | |
