2 members (chuck2213, qside), 61 guests, and 4 robots.
Topics128,021
Posts1,055,357
Members48,420
#994447 12/24/2013 12:19 AM
I am starting to restore a 55 chevy. I am looking to start by removing the surface rust and prime all surfaces to protect them.
I am wondering what is the best way to remove the surface rust? Should I take them in somewhere to have someone do it or should I do it myself (sand blasting or something)?
Ex Hall Monitor
Ex Hall Monitor
It all depends on how bad the rust is, what equipment you have and how much effort you want to personally put into it. Also just priming the bare metal won't protect it. You'll need to apply an epoxy primer.
Pitted surface rust is almost going to need to be sandblasted to get the rust out of the pits. Light surface rust you could clean up with a DA Orbital sander and 80 grit.
I would suggest Scotchbrite disc pads, less aggressive and conformable .
just-a-hacker
'49 3100 before '99
4 parts water, 1 part vinegar, scrub with red scotch brite, let set 15 min, wipe off with wet towel, dry. Rust pits turn black. Epoxy prime.
I think if there are pits that need to be cleaned out it no longer qualifies as "Surface" rust...
Vinegar (Acetic acid) is not the same as Ospho (Phosphoric acid)
Acetic acid, the active ingredient in vinegar, will form iron acetate on contact with steel. Can anyone show any good info on the effectiveness of iron acetate as a passivation layer, or on its effect on coating adhesion?
In contrast, the properties of iron phosphate conversion treatments and zinc phosphate passivation layers are well known, and actually compatible with epoxy. (edited/paraphrased from a post by crashtech on a painters forum)
Ospho or no, it still needs to be properly neutralized for the premium grade epoxies to work properly.
Give me ambiguity
or give me something else
Sir Searchalot
Sir Searchalot
Here we go again. My opinion is anti-chemical. Liquids get into all the cracks, nooks, crannies. You don't need that. Sanding and/or blast. As Tiny said: it depends on how much surface rust you have in pit form. We have just had this discussion and it's all over the place. Everyone has a different opinion on this subject. When we get done with you, you won't know what to do. You are correct about removal and prime. There are primers that you can fill (as in: bondo) over later.
x2 bart - If you are not sandblasting, good old stiff-wire wheels seem to work the best in pitted areas.
Good luck
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
Sir Searchalot
Sir Searchalot
Yes, I forgot that.
It's not that I advocate for the oshpho first approach but I recognize some will find it the route they want to go.
I just want to make sure they know there are dangers in having paint failures down the road from it but they can be avoided.
I personally prefer sandblasted to white metal, blow it off and spray/roll my epoxy.
Give me ambiguity
