| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 11 New Guy | | New Guy Joined: Dec 2013 Posts: 11 | Was this odd, any suggestions on what size wheel that makes the truck look better and handle better and i really want to get away from the splits so I can run the more modern radials from coker, | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Was it odd to have 8 lug 15" rims on a 3600 in 1946? 8 lug 15" wheels on a 3600 in 1946 was not odd. The 15" wheel was standard and a 17" wheel was optional (still 8 lugs). Maybe someone else will comment on better looks and handling. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I used the rims from a mid 80's k2500. The tires are 7.50x16 and have a nice tall appearance. They are bias ply. If looks don't matter you could go to a radial. My choice would be BFGoodrich Commercial TA's with a traction tire in back. The size would be lt235/85x16. That would put you near 32" with a tall, narrow look. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Best reason to go with those Ford 16" 8 lug rims is that they have a center section that allows you to fit in a 3/4 ton Chevy hub cap (added spring clips from Chevs of the 40s to hold the stock caps). That's what I'm running on my 53 3600 right now with radial tires, life is good. I had restored the old split rims but now days around where I live the good old tire shops are gone and the new one do not like to work on split rims. | | |
