6 members (Phak1, Woodcmiami, Otto Skorzeny, Biermann, 78buckshot, DadsFirstPickup), 102 guests, and 1 robot.
Topics128,147
Posts1,056,801
Members48,454
#991250 12/07/2013 10:27 PM
What parts of the interior were painted with hammertone, and is there a name for that color? Thanks, Scott
Jim Carter has the original-style interior paint. I know the dash for sure, but I don't know what else was painted with the hammertone.
My 46 GMC on Photobucket
The removable panels were painted the hammertone. The body was painted as an assembly. The dash, rear upper panel, corner panels, door panels, etc were all the hammertone color.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
Depending on how original you want to be - I used Rustoleum hammered paint. Mixed half copper and half silver. A quart of each was more than enough to do the doors, dash, back interior panel and trim. Painted with a brush. The drawback is the parts have to be removed and laid flat to prevent runs.
I originally used some Gold Tremclad Hammered paint, but it was way too gold, so I used the brown stuff and it met my needs, but mine isn't a restoration.
How close to the original color does this copper/silver mix get. Also is it compatible to go over a catalized enamel primer? Some of the pictures of this paint look really hammered compared to what I can tell of the original finish I could find on my trim pieces. How did yours turn out? Do you have any pictures of the finished product? Thanks, Scott
I'll take pics this weekend to provide an idea of the color. I tried to match it to a heater I bought.
See if you can see these on photobucket. Before & after pics. http://s851.photobucket.com/user/1948dodge123/embed/slideshow/1946%20Chevrolet%20PU">
That does'nt seem to work.
Thanks, I was able to open that link and see it. What I can see of my original sample trim piece, it is more of a rose/beige, and not as hammered of a texture.I read that the Jim Carter paint needs forced dry for the finish texture and I am not sure about the color? Has anyone used this product? Thanks Scott
My 41' is painted "gold" inside, but is obviously not the factory paint. So is this "hammered" gold the standard color, or are there more colors with the hammered effect?
Moderated by  ndkid275, Phak1
