| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 10 New Guy | | New Guy Joined: Jul 2012 Posts: 10 | The answer to this may be hiding somewhere in the threads, but I sure can't suss it out. Also seem to be differing opinions. I'm trying to find a replacement coil for my 51 3/4 ton GMC with a 248 ci engine. The 6 volt coil I found at Napa had the words "no external resister required" Does this mean that there is a resister in the coil and i don't need a ballast resister? (which i took out when i got the truck which the po had put in) Or does it mean I shouldn't use an external resister with a 6V coil? (which i think is true) My simple mind has grasped on to the idea that a ballast resister or an internal resister is needed for a 12V coil to reduce voltage to prevent burning points prematurely. And that a 6 V system does not need to reduce voltage to prevent points burnup. Hence, my confusion; why would a 6V coil need a built in resister and is that the coil i should use or should i find one with no built in resistance? sorry for all the blah blah blah but the more i read the more confused i get.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy roadpooch, six volt coils do not need to have internal resistors or have external resistors mounted in front of them, I have never seen a six volt coil with a built in resistor. Perhaps the writing on the coil you saw was meant to be a warning not to install a ballast resistor, hope that helps. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | My 6 volt 47 Ford had a resistor at the coil, but Ford used a very low primary coil resistance and dual points. Point life was short if the resistor was eliminated on that one, and also the 47 Mercury I owned at the same time. I've never seen a GM 6 volt system that used a resistor, however. Jerry
