0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | i put a ax15 in my c20 via novak adp. tranie was out of 2 wdrive 95 98 wrangler jeep ,it came w/o driveline-now i cant find correct slip yoke. tranie has26 spline NO space ,splines all the way around. shaft size is 1 1\8 o d chevy turbo 350 is to big anybody done this? thks art | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | It's been my experience that when you make modifications to one thing it creates the need for modifications to several other things. It may be difficult to find standard bolt in parts for this conversion. However, most driveline shops can come up with yokes and step down u-joints to fit your drive shaft if needed. Fred
| | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | thks for the reply fred guess its like putting a chevy 350 in a 57 ford ill get it just thought someone mite have done this before
thank you art | | |
