3 members (WICruiser, 2 invisible),
142
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Never installed stainless strips, do I bolt them in or weld. Thought welding would discolor them. Help please thanks | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | The body shop that painted my truck used pop rivets to attach them to the bedsides, and aligned the rivets so they were inside the bed pockets and under the fenders. It would have worked out fine, but they placed the strips a bit too high and I had to remove the rivets. My intention was to re-rivet them once I had the bed in, but they fit so snugly against the sides that I left them without rivets and they're just fine - except for the holes from the rivets. It's not that noticeable.
Based on the above, I'd recommend bolting all the strips down through the bed, then check the sides to see if they stand out. Then you could pop rivet them or just leave them. I think spot welds would discolor the stainless.
You can see mine in the gallery.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Welding would discolor the stainless, plus it would be tough to get the stainless to stick the the carbon steel bedsides. What Tom suggested seems like your best option. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Check out the Mar-k site and look under Installation Info. They say the discoloring on the stainless can be polished out. I haven't made up my mind if I want to use bolts between the stake pockets and fender or weld them in.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I pondered the same thing. I used steel angles and stainless strips. Take a look on my photobucket to see what that looks like. If you can weld well and you want to polish the welds back out you can do it. Lots of work. | | |
