| | | Forums66 Topics128,148 Posts1,056,813 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | What parts of the interior were painted with hammertone, and is there a name for that color? Thanks, Scott
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Jim Carter has the original-style interior paint. I know the dash for sure, but I don't know what else was painted with the hammertone. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | The removable panels were painted the hammertone. The body was painted as an assembly. The dash, rear upper panel, corner panels, door panels, etc were all the hammertone color. | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Depending on how original you want to be - I used Rustoleum hammered paint. Mixed half copper and half silver. A quart of each was more than enough to do the doors, dash, back interior panel and trim. Painted with a brush. The drawback is the parts have to be removed and laid flat to prevent runs. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I originally used some Gold Tremclad Hammered paint, but it was way too gold, so I used the brown stuff and it met my needs, but mine isn't a restoration. | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | How close to the original color does this copper/silver mix get. Also is it compatible to go over a catalized enamel primer? Some of the pictures of this paint look really hammered compared to what I can tell of the original finish I could find on my trim pieces. How did yours turn out? Do you have any pictures of the finished product? Thanks, Scott | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I'll take pics this weekend to provide an idea of the color. I tried to match it to a heater I bought. | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | See if you can see these on photobucket. Before & after pics.
http://s851.photobucket.com/user/1948dodge123/embed/slideshow/1946%20Chevrolet%20PU"> | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | That does'nt seem to work. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Thanks, I was able to open that link and see it. What I can see of my original sample trim piece, it is more of a rose/beige, and not as hammered of a texture.I read that the Jim Carter paint needs forced dry for the finish texture and I am not sure about the color? Has anyone used this product? Thanks Scott | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | My 41' is painted "gold" inside, but is obviously not the factory paint. So is this "hammered" gold the standard color, or are there more colors with the hammered effect? | | |
