3 members (TooMany2count, Bill Hanlon, Gray_Ghost), 32 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#991533 12/09/2013 8:45 AM
http://i113.photobucket.com/albums/n229/rgunnz/20131207_145151.jpg
http://i113.photobucket.com/albums/n229/rgunnz/20131207_145230.jpg
http://i113.photobucket.com/albums/n229/rgunnz/20131122_102433.jpg
I bought this 1951 4100 and as I was working on it. I decided to run the casting #'s but either I did it wrong or this is not a 51 engine.
Those aren't it... Right side of engine behind dizzy on the flat pad.
'Indented' not 'raised' sequence of digits.
Give me ambiguity
or give me something else
Here are locations of various codes.
The engine ID is pressed into the block as described above.
I beg to differ. The pictures do show casting numbers. Casting numbers are cast into the block. Engine serial numbers are stamped on.
Your first pic is the cylinder head, casting #3701887.
That casting # was first used in 1953.
-Tom
1950 Chevy 3100 w/ 1956 235
My bad Cletis... I was having a low coffee induced episode of dyslexic understanding and got things turned around.
Give me ambiguity
Tom/Oilrag,
Wasn't that head style (and casting numbers) only used in 1953? Would that be for an 18-bolt 235 head with the two-bolt valve cover?
Thank you all for the input. I don't know what the 18 bolt stuff means..YET... but the two bolt valve cover thing might be right. I just bought it and looked it over before trying to start it. I thought the valve cover wasn't bolted down so I didn't start it... this pic isn't the best but will take better ones tomorrow. Thanks
http://i113.photobucket.com/albums/n229/rgunnz/20131119_084354.jpg
rgunnz,
Look for the casting codes and engine serial number that are shown at the link in my earlier post. That information will allow you/us to ID what you have.
From 37-52, there were 15 head bolts; and, from 53-63, there were 18 head bolts. 1953 was an odd/transition year - the oil lubrication system could have been the older, low-pressure system (235s in trucks and manual transmission cars), or the high-pressure oil lubrication system (if the engine was used with a car with the Powerglide transmission). The various codes should clear up what engine you have.
From 37-53, there were 2-bolt valve covers (like yours); and, from 54-63, there were 4 machine-screw valve covers.
On this page, pattern #1 is the 15 bolt head and pattern #2 is the 18 bolt head.
