0 members (), 151 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#991154 12/07/2013 3:04 PM
My '48 Chevy 1/2 ton p.u. is powered by a rebuilt 1955 235 c.i. engine. I would like to increase the idle speed--a rebuilt Rochester carb. is in use. Can someone offer tech. tips to do this? Thanks!
V
V Offline
On the drivers side of the carb towards the bottom is the idle speed adjusment screw. It is on the linkage. turn it CW to increase rpm and CCW to decrease rpm.
You want to set your idle between 450 & 500 rpm.
Good luck
Dave
- Lonnie
My '54 3104
As always, the advice + information found here is really appreciated! THANKS!!!
Out of curiosity, do the Carter carbs. adjust the same way?
Riding in the Passing Lane
Out of curiosity, do the Carter carbs. adjust the same way? [/quote]
Yes. All carbs have an idle speed screw, although the location may vary.
1972 Chevy c10 Cheyenne Super
One must always ask/phrase the question correctly; my question must have read like a real dolt! I do understand the idle speed adjustment screw on a carb. As I am not familiar with the Carter carb., I thought this posting might help those with a Carter carb. as well. grin
Thanks again for all the good info.
