2 members (Jon G, klhansen),
154
Mod | | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Have a 57' short box with the original steering. Would like to upgrade to power. Have been told I can order power steering equipment for that year as offered by chevrolet. Why then do I see fellas cutting holes into the inner fender to put a shaft thru to the out of the scrap yard steering box. I assume the one from chev would have been a " bolt in ". Bills truck up here in canada says it is available. Your thoughts please, Roy
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The basic answer is that going the scrapyard steering box route is cheaper. The repop version of the original style power steering is rather expensive, around $700-800 last time I checked. It also requires you to find/mount a pump, as well as possibly getting hoses made up for the pump side of things, depending on which kit/pump is used. It also does require a hole to be cut in the inner fender to allow for the hoses to pass through.
Bill Burmeister | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Though expensive, the original style power steering is way cool (as the kids say, I think).
| | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Howdy Roy Longbox bill offers good advice, One addition to his thoughts is that the way GM did power steering on old Chevys is to use a ram assist for power. The newer trucks use a hydraulic assist recirculating ball steering box. This method is thought by most folk to be superior. They are abundant and economical. Have fun working on your truck.
Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | |
