2 members (Still At It, wilbur53), 130 guests, and 3 robots.
Topics128,196
Posts1,057,387
Members48,471
Page 2 of 2 1 2
I'm getting a retuned chip to get it running where I can go get exhaust put on it, then will Data log to fine tune it myself. Hopefully this summer I'll get a duel single barrel TBI manifold made up and can avoid that lean outer cylinder problem.
The only way to really "fix" the issue was to use three single barrels....perrty much a carb for each port. But duel tb's will work pretty cool...be something different for sure. TJ
1964 C20 LWB 292 6 cyl/sm420 parts truck.
1966 C10 SWB 292 hotrod 6/TKO600 tremec 5 speed.
1964 GMC 1500 LWB 305E V6/ SM420 "Crustine"
1977 C20 LWB 496/turbo400(soon to be 572)
My youtube channel: https://www.youtube.com/channel/UC_hdwhPFzfzpcUXyK_5-uiw
Its running real good now on the 6 cylinder tune Bill sent me. Drove it around my mountain top with no mufflers, just 4 feet of pipe. Instant throttle responce and quicker acceleration. Also, starts instantly as soon as pedal is pressed. Just got to get to the exhaust shop on my day off and he isn't booked up with other clients cars like last Monday. Got 2 Porter Steelpacks to put on it. Jim
Got the exhaust on today. Here's a lousy video driving it home. Tops out at about 57 on flat ground. Sounds good with the dual Fentons and Porter mufflers.
http://vid894.photobucket.com/album...6-47D9-8888-D806BD234EDE_zps1mubeqv3.mp4
Think it pulls 10000 lbs around real well. Now just have to remove some of the weight and find those 6 lug one piece 22.5 rims.
Did some data logging and BLM logging today. Took it out and ran it up Hwy 7 uphill. pulls real strong now. Doesn't require downshifting as low as before. Also top speed on flat ground looks to be 60 Mph. I think it has enough power to use an overdrive and go faster. Will be seriously looking for a Clark 5 spd with overdrive now. Still looking for the 6 lug 22.5 rims as well to put radials on. Will be taking it to the Petit Jean car show this weekend. Jim
Page 2 of 2 1 2
