| | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | For those running tubeless 215/85/16 on factory rims on a 53 3100, what is your tire pressure. Mine are 10 ply which is all I could find in that size and are rated to about 80 psi. Would 50 or 60 be enough. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | With no load, try starting with 40-45 psi. If the handling seems a little squirrely, bump the pressure up by about 5 psi and recheck.
Bill Burmeister | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I run mine at 45 gives a nicer ride.
Pete | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do what Bill suggests.
Between 40-45psi is where I end up. 1954 3100s
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Thanks. I have them at 50 psi. but am not driving it yet. Just wanted to make sure i'm in the ball park. | | |
