3 members (Wayne67vert, Bill Hanlon, Forty9), 86 guests, and 2 robots.
Topics128,042
Posts1,055,518
Members48,424
#986819 11/17/2013 7:16 PM
can anybody give me a round about number of turns to turn my mixture screws on my carter w-1 on my 46 1/2 ton with an original 216 in it??
hoozat #986825 11/17/2013 7:37 PM
tclederman #987117 11/19/2013 1:32 AM
mine has 2 mixture screws on it, 1 on the motor side and 1 on the fender side?
hoozat #987136 11/19/2013 2:16 AM
read the link Tim provided, you have one idle mixture screw and one idle speed screw
hoozat #987142 11/19/2013 2:28 AM
http://s629.photobucket.com/user/kurtdh519/media/009-1.jpg.html
hoozat, this is a link from your photobucket. What brand of carburetor is it?
hoozat #987868 11/22/2013 12:29 AM
its a carter....i believe the adjustment screw on the back side of the carb is for the accelerator pump?
hoozat #987870 11/22/2013 12:31 AM
hoozat #987973 11/22/2013 1:44 PM
Carburetion specialist
On a Carter W-1, the brass screw with the blunt point is the mixture screw......out approximately 1 full turn front lightly seated. The other screw is the throttle positioner screw a.k.a. curb idle screw, and rotates the opening of the throttle plate. After the engine is up to normal operating temperature, adjust this screw to adjust engine idle RPM. Clockwise will increase RPM, counterclockwise will decrease RPM.
Jon.
The Carburetor Shop
