3 members (Hotrod Lincoln, MickeyP, Brian Moore), 44 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
Page 2 of 2 1 2
#98732 01/15/2007 4:02 AM
Gocart879,
Yahoo...progress. Good show. smile smile
Stuart
#98733 01/19/2007 1:58 AM
well, im thinking whatever this problem is, it may be something stupid as well. i did more testing this evening and am now discovering that if i jump the fld and bat terminals together, i also get the alternator to charge. at this point the gauge does the same thing it was the last time. at idle, it will show maybe 10 to 15 amps, and as i increase the throttle it will boost to maybe 25 or 30. the other nite, it wasnt showing the full 60 amps(even tho i said it was). am i putting this thing into full charge or not? what harm will i cause by adding a permanent jumper into this regulator? maybe adding a switch to cut and restart the power? what do you think
#98734 01/19/2007 2:50 AM
Gocart879,
I think it would be very unwise to try and bypass the regulator. It would probably end up incinerating your alternator, battery and maybe the truck.
The full field output test should only be done for a moment. If you do this test and watch the ammeter, remember that for the ammeter to read, it must be passing that current, and the receptacle for this 'hit' is the battery.
The proper regulator will regulate voltage and current gradually, and as needed. The battery won't take 60 amp blasts long before it goes into orbit.
Stuart
#98735 01/29/2007 10:41 PM
Well, I ended up taking the regulator to a leece neville dealer, and the man there had an excellent memory of what these old systems were like, and supposedly i got a call today that it was repaired but the one guy didnt know what the man did. so im getting it tommorrow and i will let you know what happens.
#98736 01/30/2007 1:05 AM
Gocart879,
This is exciting...do keep us posted. smile
Stuart
#98737 01/30/2007 5:45 PM
it works!!!! im still not sure what the guy did, but it works like a champ. it shows about 25amps at idle and when you rev it up, it shows about 35 or so, and the headlights and all the warning lights and sirens are working so much faster and are all brighter. good news, i dont have to charge my battery up all the time anymore. Thanks so much everyone for all your help. 76 dollars later im in business.
Michael.
#98738 01/30/2007 5:56 PM
Break out the champagne! grin
Stuart
#98739 02/25/2007 9:29 PM
IF YOU REALLY DO HAVE A HEAVY DUTY 6/VT
ALTERNATOR, CONTACT RANDY'S ELECTRIC
IN CLAY CENTER, KANSAS FOR THE BEST ADVISE
AVAILABLE.
Page 2 of 2 1 2
