4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#987085 11/18/2013 10:14 PM
I removed my grill to bang out dents and to paint. while removing it some of the clips broke in half. now I 'm repainted and want to put it back on but need clips, anyone know the best place to buy new ones. all I need are the clips. thanks, brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
66flea #987099 11/19/2013 12:07 AM
thank tim. but I wondering if I could buy just the clips locally. what are those clips called away? if I can't find them then I get the kit from classic parts.
You should be able to get those clips at your local ACE Hardware or similar store. I can't think of what they are called either ha ha, but I was able to find some at ACE when I was looking to replace some on my 54. Pretty common and not too pricey.
Ill look when I'm there later today.
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
thanks chooglin, I went to fastnel and I was told there called u -nuts they were out of stock but they said I could get them at home depot or an auto parts store
extruded u-nut? I THINK thats what they're called
type-U spring nut as 66flea posted?
66flea #987377 11/19/2013 10:48 PM
J-type nut, or clip-on nut.
DG
Denny G
Sandwich, IL
let us know when/where you find them. I need a few too.
Joe
1955 First Series 3100
any NAPA should have a selection of different sizes of J or C-nuts, my local has a whole rack of body fasteners of all descriptions
got them today. the box says "860 clip nut front end assembly # 14a(1/4") screw size gm, ford, Chrysler" it was on a display at an auto body supply store. they're a perfect match. the guy at the counter said they're common and should be easy to find if you know where to look. so now you know. thanks to all that replied.
Thanks! Are those 1/4-20?
