0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 2 Moderated | | Moderated Joined: Nov 2013 Posts: 2 | i would like to eliminate the tailgate chains on my 64 c10, mabe even make the gate open sideways. info on hinges and latches would be great! | | | | | Joined: Mar 2000 Posts: 1,181 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,181 | Mar-K makes hidden latches. I used them on my '48. http://www.mar-k.com/Catalog/catalog.aspx | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | One issue with a side hinged tailgate is the weight of the tailgate hanging on the bed side. Structurally speaking, the bed sides are not very strong at the back of the truck. They rely on the latched tailgate to tie the sides together for strength. Not saying it can't be done, just saying to do it right would require some extra support to tie the bed side to the rear bed cross sill. http://www.mar-k.com/installation_hints.aspx | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | I was afraid of how the hinge attached to the tailgate. It isnt attached with very heavy hardware. Looks like it wouldnt support much weight or get loose over time. | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | Well I am not there yet, but one of my future plans will be to try and incorporate the tailgate latch mechanism from a 67-72 into my 64 tailgate. I think it would be possible to put the handle right under the upper portion of the tailgate just before it goes to single thickness (not sure if that makes sense). Also, I am not sure if I would use the 67-72 hinges or go with a cable much like the newer models. I want it to be one of those things (look somewhat original) that when people see it they have to look twice to recall that there should be chains and not the latch assembly. | | |
