3 members (baldeagle, cmayna, Gray_Ghost), 61 guests, and 5 robots.
Topics128,017
Posts1,055,338
Members48,419
#985344 11/11/2013 1:25 PM
I replaced the 216 in my 53 3\4 ton with a 54 235.
I hooked up the throttle linkage using the same two rods that were on the 216.
it is about an inch too long.
both rods have been modified.
does anyone have the lengths of the two rods?
is the pivot different for a 235?
thanks
rolf
1963 c10
rgie #985385 11/11/2013 4:19 PM
If you use the forward position on the 235 block for the pivot than the 216 linkage should attach without any modification.
My Blog
i checked, it is on the fwd pivot.
i'll have to see if i can find one.
rolf
1963 c10
rgie #987187 11/19/2013 5:02 AM
Pull your accelerator pedal to full throttle, pull your carb linkage to full throttle, measure the distance your acc pedal goes past your card linkage. Remove throttle linkage and take that amount out of the small side of linkage, weld the two pieces back together and that will take care of your problem. I had same situation last week and working fine now. Good Luck. Caution: be sure you have the curved piece at the right angle b 4 welding.
rgie #987214 11/19/2013 11:17 AM
thanks
rolf
1963 c10
